SC23-03 during copy mode. DESCRIPTION: SOLUTION ID: 111,778
SOLUTION: CAUSE: M14 (blade) trouble detection signal (excessive current) is detected.
SOLUTION: Ensure that PS30 (blade position) is attached to the cleaning unit. This can become unattached
and fall into the gears that drive the blades. If damaged or failed, replace PS30 (p/n 08AA85510).
USAGE: 1
Did that replaced the blade and the main drive motor seems to be working...does not come up without the error...I don't know where to clear it out from..... last error I got for the warming up had to go into 25 and 3 and 3 and click off and then restart..is there something like this for this error
Did you replace the blade or the cleaning unit's motor? That motor seems to be the culprit, or else something else jamming it.
If the problem persists even with another cleaning unit, then I'd search for some blown up ICP on the PRCB (board right in the middle at the back of the machine).
' "But the salesman said . . ." The salesman's an asshole!' Mascan42
'You will always find some Eskimo ready to instruct the Congolese on how to cope with heat waves.' Ibid
