Bizhub 250 with "Setting Error"
  • mrwho
    Major Asshole!
    • 4299
    Bizhub 250 (bw model) started throwing up "Setting Error" message and then turns off touchscreen. Resetting with the right-side button does nothing.
    I instructed the tech to reflash the firmware, but I'm still waiting for feedback on that.
    Any idea why this could be? Never saw this one myself before, and it's puzzling me.
    Cheers!
    Mascan42
    Ibid
  • albasoul06
    carry out the FD adjustment to allow the machine to print to the bypass without displaying the matching paper size error message
    • mrwho
      Major Asshole!
      • 4299
      Heh?
      Mascan42
      Ibid
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Cheers!
        I have never seen that. I would also have done the firmware. albasoul06, I am not sure either of us are knowing what you are referring to.
        • mrwho
          Major Asshole!
          • 4299
          Firmware didn't do anything.
          He said he's going to try swapping boards.
          I'll reply when he tells me anything.
          Mascan42
          Ibid
          • albasoul06
            FD adjustment from by-pass................. FIRST
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1075
              Does it have a fax kit, the manual says the "setting error" refers to SIP FAX Setting or LAN Failure
              Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
              Now into Ip TV KODI Boxes
              • mrwho
                Major Asshole!
                • 4299
                I'm sorry, but I don't remember mentioning anything about bypass or paper size error... Can you elaborate?
                Mascan42
                Ibid
                • mrwho
                  Major Asshole!
                  • 4299
                  I really don't know since I'm just helping at a distance, but that's a very good point - I'll ask them first thing tuesday.
                  Cheers!
                  Mascan42
                  Ibid
                  • aleksander
                    • 378
                    if still happened after checking SIP fax setting and LAN setting, try to replace the MFBS board.
                    • mrwho
                      Major Asshole!
                      • 4299
                      Thank you all for your input. The tech sent the boards over to me for testing. Had two damaged parts: the nvram and the little 8-pin chip on the PWB-A. The former is easy to get, but I'm having trouble with the nvram, since it doesn't have a pn and I need to send it away to KMBS. Before resorting to that, is there anything I can try?
                      Total clear doesn't work because the error appears before the KM logo on the screen. I was thinking of shorting the battery in order to force a reset - it can't get worse than what it already is, right?
                      Any other hints?
                      Cheers!
                      Mascan42
                      Ibid
                      • pepper38_cnd
                        • Aug 2005
                        • 1075
                        The little 8 pin chip simply tells the machine what model it is 200/250/350 I have never seen one fail occasionally they pop an error relating to that chip but it is usually reset by re-powering. As for shorting the NVRAM never a good idea in my opinion. Remove all options finisher, adf, fax (don't forget to unplug the fax battery) , HDD and disconnect the HDD power supply board in the bottom. Power it up with the right door open and see if you can get into service mode, if not try the soft reset, If you do get into service mode then do the Total Clear.
                        • mrwho
                          Major Asshole!
                          • 4299
                          Well, that explains why it gave an error on my test 350, but if my colleague tested it on a 250 as he told me, then it gave also an error. I'll double-check with him.
                          No options except for the RADF - I'll try to disconnect it also. As for the reset, is not an option - the error pops up before we can enter service mode.
                          Thanks for the input.
                          Mascan42
                          Ibid
