Hi,I on this konica1015 copier it cames on with no problem no error code,it show the green light that is ready to copy be when i try to copy the copy cames out blank,then i open the top glass and press copy check if the exposure lamp is shining and i discover that the lamp shine as i press copy bet stop shining befor it move to the other end to scan.i done know what is hapening.i need your help. thanks in advance.
konica1015
Do your copies come out white or black?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
Its analog, if the lamp was out you would get black copies,if it was completely blank i would suspect a broken corona wire ( wont always get a code with a broken wire) or bad developer unit gears which were a big problem with that machine,,,should be simple to diagnose....good luckComment
