BHc450 has error code c-0210 and cassette number 3 does not work. It seems the paper lift motor on 3rd cassette is not lifting because motor may not be good. Is there a reset to get this working
BHc450 error code c-0210
albasoul06
There is no other reset aside from ensuring that the lift mechanism is functioning freely. Opening and closing the front door (toner and image units behind this door) is typically the reset procedure for most code events.
If you are unable to open the tray, at the back side of the machine, in proximity to the tray location, is a small hole. Inserting a screw driver that is small enough and about 4 inches long to fit in the hole, straight in, you can press the release latch.
After determining that the lift mechanism is free from debris, if the code event persists, it could be an issue with the motor. It could also be a sensor malfunction as well."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
Besides all of the things Stirton pointed out, I've had a case where a gear was broken but I couldn't notice it just by looking at it - the gears looked fine until I disassembled them and saw that one of the gears had an hairline crack that would open when subjected to pressure (when trying to lift the paper) but would then return to its original shape.' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
