Konica Minolta
Tags: available, bizhub c35, calibrated, control panel, develop, fuser unit, fusing unit, image quality, imaging units, konica, life, minolta, off, olt, question, release, reseted, sea, ting, touch screen, transfer belt cleaner, zero
re chipping
hi
can you tell me if you have the program to chip a imagistics cm3120 machine
which is a cf3102 i bought it as a 3102 but it will not take a 3102 chip
thanks
carl
I am from Turkey and I have a Bizhub C350. The transfer belt unit must be changed in about 2 months. Is there a way to reset it
Also I would like to learn the prices of items of Bizhub C350 like imaging units, toners, transfer belt units etc. in other countries.Comment
Yes, the transfer belt can be reset on a C350. There is a fuse on the front of the transfer belt cleaner assy. Loosen the one screw and the cover with the contacts will come off. Replace the fuse with a 80ma fuse.The family that prays together, stays together!
Smile God created you and He doesn't make mistakes!
Relax, God IS in control!
Be still and know that I am God
Ps 46:10Comment
I replaced 80mA fuse and it was reset. Thanks very much!Comment
Originally posted by albtechmr.bizhub
i have 2 copiers konica c250
is possible to reset fusing unit ?
thankyouComment
pwbrito
Yes, you can reset the transfer belt on a C250. To reset it you must replace a 80ma fuse. The process is as follows:
1. Pull the transfer belt out.
2. Remove the bar that has the stripper finger on it. (2 screws, 1 on top and
1 on the front.)
3. Remove the ground spring from the shaft.
4. Remove the clip and then remove the metal handle.
5. Remove the small black screw. The cover will then come off and you will
see the fuse. Put the new fuse in and the belt will reset.The family that prays together, stays together!
Ps 46:10Comment
Reset your Imaging units from Minolta CF models like CF 2002, 3102, 2001, 1501, Bizhub C 350/351/450 and all the Imagistics, Konica, Develop, Olivetti and OCE models that are like the Minolta CF models.Comment
We use 63 MA fuses as they are readily available the OEM is Actualy 62 MA, but I'm sure 80 MA will do too. If you need fuses I can sell them to you.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
