View Full Version : web interface problem
haldur
03-02-2011, 09:31 AM
Hi all
when i try to open web interface of a fs-1128
to make smtp settings all advanced tab is hidden
start basic printer scanner fax all tabs are ok but advanced tab in not there :S
why cant i access the advanced tab ?? or is there any other way to make smtp settings?
Thanks for your helps
you`ll have to login password is admin00 or 2800 not sure
haldur
03-02-2011, 12:51 PM
i already did with admin00
try under scanner section there`s usually a small tab on the screen that says click here to setup smtp server,or it could be under email,hope this helps
this has come up a few times in this forums. if your using firefox as a web browser i think the same thing happens. make sure to use IE to do setups. i had this problem on a 300ci lucky for me there is a web browser on the machine that i could use to get to the advanced tab.
haldur
03-02-2011, 04:07 PM
:( i already tried it under scanner tab there is a smtp link but its not working
there is also onemore link at printer tab its not working too
trying with explorer was my first idea i tried also with chrome but none of them working :.((
anymore idea?
Eric1968
03-02-2011, 05:08 PM
I can not believe the webinterface is broken. Try a laptop or another PC.
aragul
03-03-2011, 12:03 AM
Have you tried updating firmware?
haldur
03-03-2011, 08:37 AM
i tried with different pcs all is same but i didnt update firmware i only made language update
my firmware version is 2JN_2F00.022.009.2010.11.17
is there any newer one? my distributor says no
