Bizhub 600
  • Darren King
    copiertech
    • 652
    Bizhub 600
    I am working on a BZ600 that seems to lock up when the fax TX report prints. When it locks up you have to unplug machine to restore operation. I tested it several times with report on and with report off. Each time with report on it locked up, and each time with report off it didn't lock up. So I am kinda sure this is the problem.
    Has anyone had this problem?
    Leaving the TX report off is not an option unfortunately.
    Thanks for the help
    Darren
  • aesthetics1
    • May 2010
    • 148
    Try firmware first and foremost. Make sure you specifically update the fax board firmware when you do so, in addition to the rest.
    I would try these steps in the following order:
    1. Firmware
    2. Data clear in service mode, and re-configure the device
    3. Replace the fax kit/mount kit with a known good unit
    4. Move on to boards and memory
    Let us know how it goes.
    • Darren King
      copiertech
      • 652
      Well I was at the machine Friday and udated the firmware. It seemed to fix the problem. I tested it and no lock-ups. I will call them Monday and find out for sure. Will update post when I find out. Thanks aesthetics1 for the advice.
      Darren
      • RRodgers
        • Jun 2009
        • 1947
        Darren
        Stuff like that is almost always firmware related.
        • Darren King
          copiertech
          • 652
          All seems well with the Bizhub600. Almost a week and no calls from customer
          Thanks again
          Darren
