Is there an original on the glass??! Try doing CCD adjust in service mode followed by Auto gradation under additional functions key. that should solve your problem.
When the machine errors the sub code should follow the E020 "****", if not you can find it in service mode, without it youdo not know which colour needs attention
Try cleaning black toner monitor first (1 screw to slide out just below drum) If you dont have any developer mix you could do a stir and that may get you going. Or you could reinitialize that color to fool machine
You can adjust document recognition sensitivity in service mode(I think its called doc rec) Move the number a couple of points at a time (you don't want it to recognize dust)
Thanks Other Tech This value in doc rec DA-XS DA-XE DA-YS DA-YE 24 8 32 24
DS-Doc DS-PRJ DS-OHP 21 28 22
What I can change number I try change all value increase Now machine to work copy black is good but color stop one in yellow one in blue and one in red at random What is compromise ? Machine is new work only 72000 copy .
Thanks Other Tech This value in doc rec DA-XS 24 DA-XE 8 DA-YS 32 DA-YE 24
DS-Doc 21 DS-PRJ 28 DS-OHP
22
What I can change number I try change all value increase Now machine to work copy black is good but stop in color one in yellow one in blue and one in red at random What is compromise ? Machine is new work only 72000 copy .
Thanks Other Tech This value in doc rec DA-XS 24 DA-XE 8 DA-YS 32 DA-YE 24 DS-Doc 21 DS-PRJ 28 DS-OHP 22
What I can change number I try change all value increase Now machine to work copy black is good but color stop one in yellow one in blue and one in red at random What is compromise ? Machine is new work only 0072000 copy .
