light copies on konica 200,250,300
  • runthon
    • May 2025
    [CQ] light copies on konica 200,250,300
    is it the toner? is it the developer? Is it the drum? We have a lot of reapearing problems with these units regarding washed out copies. Sky shots are very faded gray
  • Hansoon
    • Sep 2007
    • 3350
    Is it a Bizhub? Is it Color? Is it BW?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • runthon
      light copies
      they are all black and white copiers
      • CraigW
        • Dec 2010
        • 417
        I recently did battle for light copies on a 200 recently. It was caused by the drum unit. (about 15k into the 1st PM) The drum had the normal usual slight ring at the rear that you see on all of these ( I have seen machines down to bare metal that still copy ) Overall light, toner % fine. And I was getting fan codes as well.
        I managed to get a used drum to work by messing with the ATDC levels a bit, then returning to original value.
        • bigdcopy
          • Dec 2010
          • 70
          when you replace the drum it is recommended that you replace the developer (DV310) at the same time and then run F8 don't forget to go into the counters and reset the drum and developer double check it sometimes it does not reset.
          • eg101
            • Jan 2005
            • 131
            I nomally change the Developer UNIT, not just the developer (DV310) every other drum replacement.
            Saves a lot of call-backs for C/Q problems and any other drum wear troubles.
            • earthOO7
              • Mar 2011
              • 6
              how about the scanner section... check the lamp or the mirrors
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                Just out of curiousity, you know you can set the scan adf densidty in the User setting menue?
                Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                Now into Ip TV KODI Boxes
