Konica Minolta 8050- SC41-02 error code. Any suggestions?
  • JSelman
    • Jul 2025
    I just got a call about this and have no idea where to start.
    Anyone have a service manual or know what the error means?
    Any help would be appreciated.
  • Luther
    • May 2006
    • 682
    yellow polygon motor failure
    • JSelman
      Thanks for the reply Luther,
      From what I can put together it sounds like 41 error is a failed write/laser unit or suction/exhaust fan.
      the second part, 02, indicates the color.
      "yellow polygon motor failure"
      Is the motor inside the laser unit or is it a single part that can be replaced?
      • Luther
        • May 2006
        • 682
        it comes as a unit...i dont know if you can lube the shaft on the motor you can try it
        • Luther
          • May 2006
          • 682
          and i think 42 codes are fan codes, 41 codes are write unit codes and the sub code tells you the color, its either a failed write unit or the printer control board...good luck
          • JustManuals
            • Jan 2006
            • 9838
            Just Manuals | The Internet's largest selection of manuals | Instant Downloads
            Paul@justmanuals.com
            • empiru
              • Feb 2011
              • 229
              Hi!
              I had the same problem with a Bizhub Pro C500 - almost the same machine and I only cleaned very vell the exhausting fans from the writing units and all the path of the air from around them. I did this about 3 weeks ago and the machine still works fine, no problems...
              I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
              • henry finley
                • Feb 2011
                • 101
                Re: Konica Minolta 8050- SC41-02 error code. Any suggestions?
                Bringing up an old thread with a question. It's May12 and it's back to some serious heat in my non-air conditioned house. Coult this error just be a normal condition from a C-500 idling several hours? I turned off the machine for 15 minutes and when I turned it back on the error was gone. Thank you.
