How do I enable printing in a Konica 7155
  • Maindron1
    • Mar 2011
    • 38
    Hello,
    I just bought a copier Konica 7155 and I just find out that It is not set up for printing and I would like to set up the printing on it.
    How do I do it?
    Please help.
  • Pier
    • May 2011
    • 5
    Hi,
    Have you bought IP controller also?, It was option. The password to configure the nic is sysadm.
    good job
    • remati
      • 149
      ...IP 511...If I think.....
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        yep, you need the print controller, its a lump screwed on to the back of the machine in the upper most right hand corner.
        if your back panel is totally flat, no printing for you.
        Speaking of which, i wonder how many of these print controllers have been cooked by dumbasses having the machine pressed right up against a partition panel sealing its cooling vents. I've certainly seen a few die that way in my time.
        • CT Copier Repair
          • Mar 2010
          • 304
          Many dumdasses Perth
          Many many dumbass customers
          had a lawyer with one in a closet
          couldn't open the front door oh were jams fun
          and he was surprised when it finally jammed
          told me to take it out
          i told him sure and when my back goes out I;ll sue
          so he told his secretary to do it
          she told him to F himself
          so he decided to do it and dropped it and it shattered his foot
          And I laughed my ass off
          many many dumbasses
          • CT Copier Repair
            • Mar 2010
            • 304
            many many dumbasses
            best part i forgot
            he wanted to sue me my company at the time and the manufacturer the manufacturer cooked his ass
            and he couldn't get a copier from anyone. No one would sell him one
            I sold him a typewriter IBM Selectric and charged him 100 an hour to service it 3 hour minimum
            • ddude
              General Troublemaker
              • 473
              If you you do not have a controller, I do have one available, complete with the attachment kit which is required. If your machine is equipped with a controller, there will be a bulge on the back cover, it will not be flat like discussed earlier.
              Just because you see a NIC port and a parallel port does not mean you can print on a Konica box, those ports were for servicing and firmware loading.
              2000 mockingbirds = 2 kilomockingbirds
              • Maindron1
                • Mar 2011
                • 38
                I used the one I had from my old copier and It is working fine now and I did not even have to reconfigure it since I am using the same computer to print to it.
                And by the way I had it against the wall blocking the cooling area (Guilty as one of the dunbasses), I had to pull it away from the wall. Thank you for adding the remark.
                Originally posted by Maindron1
                Hello,
                How do I do it?
                Please help.
