Konica Minolta C6500 Wrinkle problem
  • mikcia
    • May 2025
    Anyone been having problems with a bizhub c6500 wrinkle issue? I'm printing 12x18 duplex on 80lb dull coated text and i got nothing but severe wrinkling on my outputs......BTW, Konica Minolta copiers are nothing but garbage.
    anything to fix this issue? i swear i think the techs are clueless sometimes.
  • Jules Winfield
    • Jul 2009
    • 821
    Re: Konica Minolta C6500 Wrinkle problem
    What media type setting are you using? Are you feeding the paper from the drawers or from the bypass tray? Are you sure the paper you're using is within specifications? And when I say specifications I mean what is written in the manual stating what type/weight of paper can be fed from which specific paper source, not what the salesman said the machine would run.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • Hemlock
      • 432
      It's your paper.
      “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5000
        • Jules Winfield
          • Jul 2009
          • 821
          Originally posted by zoraldinho
          [ATTACH=CONFIG]10820[/ATTACH]
          Aren't you worried about dingleberries building up in the fuser?
          • Ianizer
            • Jul 2011
            • 380
            Lol! Nice first post, Mikcia.
            Had days like that myself.
            Deep breath...
            Woosaa...
            I'd check those media settings.
            First, we need to know the gm2. 80# Text? Index?
            Next, where does the wrinkling begin? Post-fuser? Pre-fuser?
            6500's a decent box when it's dialed in.
            Got one in the morning, in fact. I'll check CTN for your response while I'm in front of it...
            -I
            My name Peggy.
            You got problem?
            • Ianizer
              • Jul 2011
              • 380
              Originally posted by Ianizer
              ...I'll check CTN for your response while I'm in front of it...
              6500 call done and done... No word from Mikcia.
              Sorry I couldn't be there for you, bruda.
              -I
              My name Peggy.
              You got problem?
              • RickB
                • Sep 2010
                • 5
                If it's 80# text, lie to the machine & set it @ 20# plain.
                Works for me every time.
                I support 12 of these on my own (no tech support for 3 years) & have very few problems.
                  • 22937
                  Way to go. You do realize that you're insulting the same individuals that you are asking advice of.
                  I would start by trying some different media. Coated paper stock is a nightmare with most any MFP. =^..^=
