Hello, paper out of all trays are off ( this is one of the problems I'm having with this machine) top to bottom ( main scan) had to adjust all paper trays as far up as possible ( set to -3.00) what would cause the registration to go that far off?
konica bh c353 registration problems
Re: konica bh c353 registration problems
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
Paul@justmanuals.com -
Thanks, but I have a service manual. I'm just wondering what can cause the registration to get that far off!Comment
AC,
I recommend:
1
Reload all paper trays like you're diapering a newborn.
2
Zero all electrical paper registration adjustments.
3
Perform mechanical paper registration rough adjustments 1-2-3-4-bypass.
4
Perform fine elctrical adjustments to dial in.
-IMy name Peggy.
You got problem?Comment
Thanks Ajit, It's a main scan registration problem (top to bottom) not a feed direction problem. Thanks anyway.Comment
Hi, Have you replaced the printheads/laser assy?
I had something similar on the same model and the fault was with the printheads(probably the black). as you know you can adjust the registration via the admin/service modes but if one of the printheads is faulty you have no chance.
I changed them and the fault went away.
good luckComment
traxdc, color looks good as well as black, does that make a difference? If one shifts, they all shift! ThanksComment
Hi
Black is the only one that cant be adjusted (set as a reference point). you can adjust the colours via small adjuster pots that you can access on the printheads (black one is hidden). It could be the black registration has shifted and you are compensating by adjusting the other registrations. try swapping the black and another colour to see if that makes a difference. the setup sequence is in the manual, have a look first!!!.
if its top to bottom and you have adjusted the tray guides then you have eliminated any drift caused by the cassettes, and if the problem is present from all paper sources then you can elimenate the paper path.
if you have the time its worth checking this out.
i hope this is helpfulComment
good luckComment
