Bizhub C353 - Cannot change density for the second document when scan to PC. The old Bizhub 250 can do it. is there any work around please? Thanks in advance!
Hi
Thought to provide some more info
The customer scans from the platten glass to PC documents that require different density adjustments. Now they got a Bizhub C353 and the density adjustment is available only for the first scan and all the rest of the documents have to use the same setting until you hit "Finish".
The customer does not want separate emails for each document.
