Cannot go into User's menu to set-up paper trays BizHub 1035f
  • Machinercylr
    • Dec 2006
    • 73
    It started with an error code of C0500...After reading post on how to clear this error code after resolving problem (Bad fuser) Encountered a new problem. For some reason now an error code that states: "the paper size cannot be detected in the current position against the edge guide of universal tray 'Tried to use the User's settings on display panel to check the settings, however, the only menus that can open are Admin and Utility. Looked through the User's manual Basic and Advanced, but nothing. Does anyone know what key strokes that will open the User setting display on this machine? Thank you for all your help,Steve
