Konica Minolta Bizhub 250 Fuser reset
  • Copyexp
    • Aug 2011
    • 1
    Hello all,
    I need to know if the Bizhub 250 (BW) uses the same fuse to reset the life of the fusing unit as the Bizhub C250 (Color). Or a different method is used.
    Thanks in advance......
  • nightshade
    Chromographic Supremesist
    • 158
    Re: Konica Minolta Bizhub 250 Fuser reset
    Might be off a bit, but isn't the fuser reset in tech rep mode on the B/W's
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Hansoon
        • Sep 2007
        • 3355
        The fuser unit of the KonicaMinolta Bizhub 250 BW does not need resetting and therefore does not have a fuse. I you want to reset the counter for whatever reason go to tech rep menu>counters>special parts counter and scroll down to fuser to reset.
        Hans
        “ Sent from my Intel 80286 using MS-DOS 2.0 “
        https://www.copytechnet.com/images/smilies/biggrin.png
        • ni311
          • May 2008
          • 658
          I cannot see why you would like to reset the fusing unit for Bizhub 250 as long as there is no warning about the life of it in User Mode and the copier won't stop if you over-use the fusing unit.
          Konica Minolta Error Codes - Explanations and Solutions
          • nightshade
            • 158
            There is no warning about live but the copier will stop when the fuser life is over.
            • ni311
              • May 2008
              • 658
              Are you sure that on Bizhub 250 the copier will stop working if the fusing unit reaches full life? I had several of these on the field and I never see this happening.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                since when does a bh250/350 fusing unit even last life - unless of course you simply ignore the score marks on the heat roller from the thermistor and claws which occur anywhere from 150k onwards depending on customer toner coverage.
                • ni311
                  • May 2008
                  • 658
                  I changed a lot of fusers or fusing rollers but never resetted a counter... I thought you know what you're talking about...
                  • nightshade
                    • 158
                    To most customers having a life over saying on the screen is the same as being down. Sorry for a little confusion.
                    This last part of your comment though, is completely un necessary.
                    • juve
                      • Dec 2012
                      • 86
                      Originally posted by Copyexp
                      Hello all,
                      n
                      hello
                      no fuse,just service mode ans reset
