Error C-0401
  • Dedotch
    • Oct 2008
    • 40
    Error C-0401
    What and where is the LU Unit? The manual says no 24VDC supplied to the LU unit. Could it be a plug.
  • tbkarthic
    • Feb 2011
    • 66
    Re: Error C-0401
    machine model?
    drugstore-catalog.com
    • Dedotch
      • Oct 2008
      • 40
      Re: Error C-0401
      Sorry Bizhub 6500
      • nightshade
        Chromographic Supremesist
        • 158
        Re: Error C-0401
        The LU-202 is the large capacity tray.
        Big thing that is attached to the right side of the copier, ganerally has alot of paper in it.
        Probably came unplugged if the copier was moved. Or has a bad board in it or the copier.
        • kingarthur
          • 1304
          Re: Error C-0401
          You've got the manual...yet you cant identify the "LU"......
          • tbkarthic
            • Feb 2011
            • 66
            Re: Error C-0401
            you first remove that lu unit and pow., on the machine and check if the the error not come. check the sensor for (paper take up) and main motor
