Trying to take more control from a certain customer. Anyone know what message appears when you set "Toner Life Warning" to "Service" instead of "User".
That will do what you want, but ... you'll get a service call condition every time the customer needs toner. Is that what you really want? =^..^=
It's what the key operator wants, it's kind of a "mine is not to question why" situation.
But technically, the key operator should be able to install the toner, thereby clearing the message. Correct? Because the drum/fuser/transfer are defaulted to "Service" but there is nothing special we do beyond replacement or re-chipping.
Correct. The customer can still change the toner by exactly the same method as before. You just get the red "Call For Service..." screen.
Is the idea to prevent endusers from continuing to run the machine after "Add Toner" is displayed, de-toning the developer? =^..^=
Yes. That is what the customer is convinced is happening. It's literally a life and death situation. They supply meds for nursing homes and their charts are color coded.
In That case, I have better Idea.
Switch ON (SMTP TX) email reporting of toner low and add toner to this "Operator" email, whose responsibility is to change the toner or perhaps make sure you have also "low toner" email sent to your base so your folks have a proof that machine was asking for it, and you reacted in time, so their machine has plenty of supply too. And it will be a solely responsibility of the Operator to make sure he reads his emails.
Good Luck.
