BizHub C253 - Scan To Email
  • RMFTechnologies
    • May 2025
    Hi All,
    Scan to Email on a bizHub C253... For the life of me I can't get it to work...
    It's scanning to an Exchange 2007 Server on Windows Server 2008, located at a different office over a permanent site to site VPN. Both offices can ping the c253 perfectly with no issues.
    Have tried with No Authentication, With Authentication, SSL Off, Start TLS and Full SSL. Have even created a dedicated Receive Connector on the Exchange Server with Anonymous Authentication but still cannot get the unit to Scan to Email.
    Firmware / ROM Version Details as follows:
    MFP Controller BOOT Program A02E0Y0-1E00-G00-03(00)
    MFP Controller SubSet Program A02E0Y0-1F00-G00-70(00)
    MFP Controller A02E0Y0-0100-G10-J8(00)
    Operation PANEL Message Data A02E0Y0-8100-G00-J1
    FAX Board Controller1 15LA-0040-G01-07-000(00)
    FAX Board Controller2
    IR A02E0Y0-0023-G00-34
    PRT A02E0Y0-0050-G20-07
    ADF A01H0Y0-0024-G00-11
    Finisher
    Panel Micro-Computer A02E0Y0-8900-G00-00
    LCT
    Loadable Device Driver
    System Controller A02E0Y0-1000-G10-J8(00)
    Printer Controller A02E0Y0-3000-G00-65
    Printer Controller-Font A02E0Y0-3F00-G00-22
    Printer Controller-Demo Page A00J0Y0-3E00-G00-00
    MIO A02E0Y0-5000-G00-80(00)
    PSWC A02E0Y0-5100-G00-02(00)
    MIB IF A02E0Y0-5200-G00-J1(00)
    IPP IF A02E0Y0-5300-G00-82(00)
    External Controller IF
    TCP/Socket A02E0Y0-6300-G00-J1(00)
    Open API A02E0Y0-7000-G00-11(00)
    Operation PANEL A02E0Y0-8000-G00-J7
    CSRC A02E0Y0-8300-G00-80(00)
    PIC A02E0Y0-8200-G10-23
    Any assistance is greatly appreciated.
    Cheers,
    Ray
  • BIG PAPA
    Da Boss
    • 234
    Re: BizHub C253 - Scan To Email
    What is the error you are getting?
    sigpic
    • RMFTechnologies
      Server Connection Error... That's all it says...
      No further description from there
      • emujo
        • Jun 2009
        • 3009
        Take the MFP off the network. Put a laptop on the same port and give it the exact IP scheme as the copier. Try to telnet the server using the correct port. "server connect error" means the MFP cannot connect with the server in question. Could be port issues, firewall setting using the VPN. Emujo
        • DallasTech
          • Feb 2007
          • 119
          Stupid question, but you have enabled the SMTP relay in Exchange right? Do you have any other MFP's that use this server to send email? Maybe authentication is set too strong on Exchange as well?
          • habik
            • 2013
            I had very similar problem, relay it was!
            Firmwares HERE
            • RRodgers
              • Jun 2009
              • 1947
              Try pinging the exchange server from the copier, and be SURE the time is correct on the copier! Date as well. Also, you have an admin email inputted.
              • mrwho
                Major Asshole!
                • 4299
                Thank you very much about the date/time thing. I had a machine located in 2041. I warned the operator about the possibility of the machine being a T-1000 disguised as a C300.
                Reps to you!
                Mascan42
                Ibid
