Bizhub 252 Fuser Ghosting
  • jfishtech
    • Jun 2025
    Hello and thanks for taking the time to read this. The machine is a NEC 25C2, which is just a rebranded Konica Minolta Bizhub 252.
    When the customer prints or copies, a ghost image appears every 3 inches of whatever was printed before. I've traced it down to the fuser, as I can see the toner stuck to the rollers. I replaced the fuser with a new one in March. This fixed it for a month before they called back saying it was doing it again. I bumped up the temperature that time. Fixed it.
    Now the customer called me a week ago, and said it was ghosting again. I went back in and the fuser had toner sticking to it, and the pages coming out of the machine were cooler then usual. So I went ahead and replaced the fuser one more time, but still was ghosting. I tried thick paper setting, and it is still ghosting.
    It has to be keeping enough heat to keep the machine going into code, but not enough to fuse it to the paper.
    The problem has to lay either in the wiring harness that powers the lights, or the control board that keeps the fuser hot. But I'm not entirely sure what I am looking for since I have no error code to point me in the right direction. Any help will be appreciated.
  • SmellsHot
    Head Tech
    • 512
    Re: Bizhub 252 Fuser Ghosting
    This might sound silly, but ....did you check the envelope levers?
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • PeterG
      • Jul 2008
      • 177
      I think someone is about to make an embarrassing discovery.
      • Hansoon
        • Sep 2007
        • 3374
        If not an "embarrassing discovery" it might be non-OEM toner as well......
        Hans
        โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
        • mo0651
          • 1054
          I would hate to think the levers are set wrong on 2 fusers, but I've seen that before.
