Tech thinks its the finisher, then the machine, now is clueless! HELP! I'm a girl..
  • rbkmiller
    • Jul 2025
    [Jamming] Tech thinks its the finisher, then the machine, now is clueless! HELP! I'm a girl..
    I am trying to troubleshoot a Konica Minolta C550 BIZHUB.&nbsp; It is jamming paper inside the finisher once it leaves the printer.&nbsp; Initially we thought it was a bad finisher due to staple errors and jamming.&nbsp; Used Copier dealer swapped them out. Got new finisher in and same problem.....Paper jamming inside the finisher just above the paper punch area in a cavity.&nbsp; It is not clearing the open space.&nbsp; It is folding over and getting loosly stuck.&nbsp; I have attached a picture for your viewing pleasure.&nbsp; The paper is the light white spot...not a good quality photo.&nbsp;The copier is in a building that may not be level.&nbsp; Not sure if there is supposed to be a 1/4" space between the printer and the finisher that is properly attached.&nbsp; Please give your feedback as we are ready to throw it out the window even though with the right knowledge it could easily be fixed.<br><br>Many thanks!&nbsp; To the winner goes a virtual fifth of liquor and bragging rights.
    ps picture wont rotate for me but you can get the gist.
    RBK in North Seattle
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Tech thinks its the finisher, then the machine, now is clueless! HELP! I'm a girl
    This a stupid question.... Did the tech set the correct pk (punch kit) in service mode? Also check the hole punch is correctly installed and connected.
    Can you post which finisher this is label in one of three places. one is bottom of machine inside front cover, on outside bottom left or inside (between copier and machine) on bottom rear.
    Also check the jam codes in service mode and post that as well please.
    • rbkmiller
      This picture is of the inside of the front cover of the finisher when you open the door. The guy didnt reset the punch. He just stared at it and said I've never seen this and need to talk to people. We assumed the problem was with the finisher, but the second one is having the same jamming problem.
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        what is the jam code? Have the service guys tested it without the finisher? It could be a fuser/exit problem and you would still end up with a page in the finisher.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Place a call to the tech's shop and request another tech be sent. I am serious, even if he does not know the problem he should be smart enough to fake it and not have the customer loose faith in him. That machine has an internal jam counter that not only records the jam point, but the exact time it jammed. If your problem was in the finisher, the first thing I would do is remove the finisher and let it run until I fixed it. If you have a contract for service or are paying for it, you deserve better. I have gone behind my own techs and told the customer they should call and complain. I have never been to color school, but I have kept my color machines going without any downtime, including a C550 for the past 3 years in an important location. If my machine is really broke, it takes about 15 minutes for me to tell the customer when I will be back and what I am going to do. Good Luck to you.
          • Ianizer
            • Jul 2011
            • 380
            Why don't we just simplify this a bit and isolate the finisher?
            Shut the machine off, remove the finisher & bridge unit.
            Run it until it jams and let's troubleshoot that jam code...
            Just a thought.
            -I
            My name Peggy.
            You got problem?
            • rbkmiller
              Those are both valid points. I will give them a call and give em hell.
              • emujo
                • Jun 2009
                • 3009
                I'm dissapointed, "I've posted a picture for your viewing pleasure" and all we get is a image of a punch unit??? Emujo
                • mo0651
                  • 1054
                  After you clear the jam and machine comes to ready, can you choose hole punch? or does it say " feature can not be used at this time."
                  • Hemlock
                    • 432
                    What does "I'm a girl" have to do with anything?
                    Unless we're in front of the machine - seeing, hearing and feeling it as it runs (yes, we occasionally fix it by laying on of hands) - it's all just speculation. Best bet is to get another tech or have him escalate to the Konica support guy/gal.
                    Given that it's Seattle, and you guys are known for rain, I'm gonna go out on a ledge and say it's your paper.
                    โ€œAnti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'โ€ (Isaac Asimov)
                    • mitchl
                      • Apr 2007
                      • 501
                      If 2 fins are doing the same thing one would think a logical step may be to hit the firmware just to get it off the list of possibilities and as Fixthecopier said go to the counters they are your friend!
                      • rrrohan
                        • Sep 2011
                        • 1977
                        hahaha i had exact problem running up new copier and finisher the other day.
                        i dont recall what its called right now but can double check what its called when im back at work (12 hours).
                        it just initiates a paper sensor. its actualy part of the run up instructions that i myself had missed so there is a chance your tech may of done same thing.
                        some one else may know what im talking about other wise stay tuned
                        hopefully im on the right track because its literally a 10 second fix
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Service mode -> finisher -> FS-FN Adjust -> Punch F. Sensor Intensity Adjust. Hit Start.
                          should then get ok
                          • SPBE
                            • Sep 2010
                            • 70
                            should then get ok
                            What he said.
                            • rbkmiller
                              Ok! We're getting somewhere! Not sure where, but definitally somewhere! We were waiting on your responce and it was there first thing this morning. I am extremely thankful for your follow-through! I have attached two pictures of our Service menu. There is no option for the setting you mentioned, but maybe by attaching photos of our finisher menu this can help assist you in finding the correct answer. There are two new pictures to show you our menu choices.
                              You Rock
                              Rebecca
