I change a nvram and the mfbs board today. everything was fine, until i place a4 paper on the glass and the machine tell there is no matching paper in the trays. both trays loads with a4 and a4r paper. flash it back, nothing happen. someone, please tell me what should i do?
BH250 Change NVram
Re: BH250 Change NVram
What size of paper does the machine detect on the tray?' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation! -
I had a similar problem on a Di2510 which works in the same way try doing the following
1. Select the functions as follows: Tech. Rep. Mode → [System Input] → [Original Size
Detecting Option]. Then, change the setting for Original Size Detecting Option from
[No] to [Yes].
2. Select the Tech. Rep. Mode → [Function] → [F7-1].
3. Stack five sheets of blank A3 paper on the Original Glass.
4. Press the Start key to perform automatic adjustment by the Original Size Detecting
Sensor
5. Turn OFF the Main Power Switch, wait for 10 sec., then turn the switch ON.Comment
if im not mistaken, it detect a3 paper.
[No] to [Yes].
Sensor
set to others.
guys,
thanks for the info. will try it all. maybe i made mistake somewhere. will update to you all. thanks again!Comment
erm.. i still cant find any clue about it in the manual. what else should i say except millions thanks. 3 months ago, i change 1 nvram but the no need to adjust f7-1. probably this is the new board (got jumper to change from 300 to 400mhz), and it need to set like you told. again, thanks!Comment
