Bizhub 200-350 - Doubling the Transfer Roller Life
  • cwatts
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: Bizhub 200-350 - Doubling the Transfer Roller Life
    not sure I am familiar with that problem. In the past 12 years I have maybe changed 5 transfer rollers on that class of machine. I have over 300 in the field.
    • mo0651
      • 1054
      Not the transfer roller wearing on the drum....ds collars on the dev unit.
      • Hansoon
        • Sep 2007
        • 3350
        Have never had transfer roller guide plates damaging the drum until now, but felt always uncomfortable about half moon wear on the both levers/tabs which touch the drum surface. To compensate we put in severe cases an extra shim 0.2mm under the levers to keep the guide plate of the transfer roller away from the drum.
        BTW its important that the little collars on the transfer roller ends, which keep the transfer roller foam at a defined distance to the drum surface, can turn freely. Otherwise they too can damage the drum surface.
        We almost never replace the whole transfer roller assembly. When they are dirty just clean them with plain water and blow them off with an airgun to dry.
        Hans
        “ Sent from my Intel 80286 using MS-DOS 2.0
        https://www.copytechnet.com/images/smilies/biggrin.png
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Those transfer rollers are worth next to nothing, I've never really had much of an issue with them other than squeaks but I do mostly change them if I see excessive wear or they've done 150k or more. I keep them new in the car anyway, along with drum, dev unit and developer. The dev unit has to be seriously impressive to get used again or it simply gets tossed in the garbage - I dont mind as its less work that way
          • Hansoon
            • Sep 2007
            • 3350
            Great when your boss agrees with that......
            Hans
            • SmellsHot
              Head Tech
              • 512
              This may sound crazy, but the transfer roller rubbing on the drum is about as much of a problem as the ds collars are. If the white guides on the Trans roller are worn down the slightest and you pop a new drum in there, you will be back within 10% of that drum life because it will have etched its way into the drum coating. Keep an eye on those white tabs
              Good piece of advice "cwatts"!!
              Everyone has the right to be stupid. Some people just abuse this privelage more than others
              • goldencup
                • Nov 2008
                • 366
                Hans
                sir, may i know where is that half moon located? (may i have a picture) I would like to reconfirm about the shim if is it really 0.2mm and not 2mm? Thank you
                • ni311
                  • May 2008
                  • 658
                  The two white plastic holder on each end of the transfer roller are wearing in a half moon shape. You won't see a half moon in the machine...
                  Konica Minolta Error Codes - Explanations and Solutions
