C6500 / C6501 Fuser Belt Lifespan
  • Nor
    • Jun 2011
    • 18
    I am replacing fuser belts approximately every 200,000 prints, and not every 400,000 which is the recommended lifespan. The belt appears to start to disintegrate (ie. thin clear top layer bubbles, breaks, and starts to peel, thus leaving marks on prints. It happens on both sides about 1 to 2 centimetres from the edge. Does anybody else have the same problem?
  • 1FRY1
    • 51
    Re: C6500 / C6501 Fuser Belt Lifespan
    No problems here ?? apart from the odd one that peels early
    What stock are they using??
    • Nor
      • Jun 2011
      • 18
      Paper Stock is Burgo (Italian) and 80% is 300gm. Matt 330x487. The remaining 20% is same size, 135gm., 170gm.,225gm. and 250gm.
      This stock leaves a lot of paper dust(white) both in the paper trays and throughout the machine. Is it possible that the edges are rough and that causes the peeling on the belt?
      • brian155
        • Jan 2008
        • 50
        is it single click SRA3, half 400k life?
        • Nor
          • Jun 2011
          • 18
          Brian 155, Yes
