what purpose is the extra scan button. customer cant scan and I.T. guy says when he hits extra scan button it says this feature needs option unit. CAN YOU SCAN USING THE FAX SCAN BUTTON AND IS THE EXTRA SCAN A OPTIONAL UNIT THAT NEEDS ADDED. CUSTOMER WANTS TO SCAN TO PDF. THANKS FOR ANY ADVISE. we dont have alot of experiance in this end of the copier
konica 250 scanning
Re: konica 250 scanning
you dont need any extra kit to scan to email, it is easy to set up on either model, you use the scan/fax button, not sure what the extra scan button does, as no one actually uses itTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
The EXTRA SCAN button is for IP Scanning, similar to internet faxing. Antiquated technology, never seen it in use..The 250 will scan via SMB, FTP, or email in a PDF or TIFF format. What you need is someone to set it up for you. Optional HDD is recommended as it will increase speed and # of pages you can scan. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
The Extra Scan button will be enabled with Netwok fax/ IP Scan upgrade chip, which we have only had two customers use it for sending fax from pc's. Optional PC Fax/Network Fax software needed, which has no Win 7 support.Comment
