B 350 shows "Pull out the selected tray, then load paper"
  • Eugene74
    • 70
    [Misc] B 350 shows "Pull out the selected tray, then load paper"
    HI there,
    Can anybody help me with this problem. I've got a machine in the field, with only 50K copies on. Suddenly the machine give a message, out of both paper cassettes "Pull out the selected tray, then load paper" when you make copies, run test mode from tech rep, and even when you press test button on Printer control board at the back. I have replaced:
    Paper trays
    Paper feed units
    Paper lift-up section (Whole unit at the back of tray)
    Power supply
    PWB A (Printer Board)
    Firmware
    Could any body assist me in this regard, I would appreciate it.
    Many Thanks
    Eugene
  • SmellsHot
    Head Tech
    • 512
    Re: B 350 shows "Pull out the selected tray, then load paper"
    Does this usually happen after a few sheets have ran thru? I would start with the registration clutch and if that doesnt fix it u have to replace the clutch that is located behind trays 1&2. U have to remove both trays and feed assys. Then that assy can come out. It has a belt and some gears on it. About 6 screws and clutch connector(can be a pain, unplug it by going thru the side door and not from bypass area!
    Hope this helps
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • aleksander
      • 378
      Check the gear drive in drive section.
      • digicor
        • Jul 2008
        • 1152
        im my experience clutch problems just give you jam errors from not passing the paper down the line.
        I think you might check the sensor's where they connect to the main board, there might be a fuse out that controls these,Im not sure which one, but there are several and they look like little black mini eprom chips.
        just a thought
        • 907tec
          • 434
          I had a similar issue: the machine would get 4-5 pages into a print job, then pop up with the same message. All the sensors looked good in I/O checks, and the trays/feed assemblies appeared to be in good shape. Tried the old trick of padding the rear side of the paper tray to push the drop-down assembly further...nothing. The problem continued even after rebuilding the paper feed unit, cleaning the clutches and buffing up the shafts. I ended up installing a new feed assembly, rather than waste time on further diagnosis. Unfortunately I ended up taking the shotgun approach, but replacing the feed assembly seems to have done the trick.
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            Did you replace the size detect unit for either of the trays?
            • Don N.
              • Nov 2011
              • 409
              OK Here's the fix. One beer owed if it works, o.k.?
              Replace the photosensor in the verticle transport section that is visible when you open the door above the bypass.BH350 Verticle feed 1.jpgBizhub 350 verticle feed 2.jpg
              • Eugene74
                • 70
                Hi Guys,
                Thanks for all the info. Just a bit of feedback regarding the problem. I eventually got it sorted. Don unfortunaly the senson wasn't the problem, but we'll make a plan to have that beer another time.
                We've replaced the whole registration section in the right hand door, and it fixed it. It would appear to me that it was detecting the wrong size paper at registration and didn't correspont to the tray size.
                Thanks again for all the input.
                Kind Regards
                Eugene
                • digicor
                  • Jul 2008
                  • 1152
                  this is good info to know
                  • Don N.
                    • Nov 2011
                    • 409
                    Sorry, but I ran through this post so fast that I thought you had already done what smellshot said. This is the first thing the Kon-Min knowledgebase says to do. When that didn't work for me once, I remembered another tech had same experience. It usually is the reg. clutch, but we each have one instance of the vert. sensor doing same "replace paper" symptom.
                    BTW, you can get CRC electronics cleaner from Ace Hardware and spray the clutch out. Seems to work great for two guys I got that from. One has done it for years on Sharps and one on these KM's. I sprayed one yesterday for jamming at reg. clutch and ran over 100 ok. We'll see. Glad I've saved the 5 or so clutches we've replaced in past year. Gonna flush them out and recycle them.
                    • Hansoon
                      • Sep 2007
                      • 3350
                      I blow those clutches first out with compressed air and than flush them with brake cleaner. Worked always until now for me.
                      Hans
                      “ Sent from my Intel 80286 using MS-DOS 2.0
                      https://www.copytechnet.com/images/smilies/biggrin.png
