bizhub c252code c-1183
  • Bri Ski
    • 48
    Just got this one in. Finisher was tweeked. Any common cause for this particular code? Thanks for any suggestions
  • scottybbb
    • Dec 2010
    • 126
    Re: bizhub c252code c-1183
    See if exit tray is up to far.Exit tray is not in the home position.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Darren King
        copiertech
        • 652
        Make sure the bins are making contact with the upper limit sensor actuator on the finisher just under the exit.
        Hope this helps.
        Darren
        • Nelo
          When outputting paper to Tray 3
          PROBABLE CAUSES:
          1. The lower adjust plate is not in the correct position.
          Note: The FS-519 is configured with an OT-602 (Additional Output Tray) installed in conjunction with an MT-502 (Mailbin Kit) or a SD-505 (Saddle Stitcher Kit).
          Position the lower adjust plate in the correct position according to the attached OT-602 Installation Manual.
          2. The bracket that holds PS11 is malformed or the sensor may have failed.
          Replace the PS11 holding bracket if deemed necessary.
          At power up
          CAUSE: PS11 has failed.
          SOLUTION: Replace PS11
          After servicing the finisher.
          CAUSE: Improper wire harness routing causing interference with the PS11 elevator home sensor.
          SOLUTION: Route the wiring harness through the harness holder correctly.
          Worked for me. Region - Oceania
