Bizhub 283 - Trouble setting up scanning with SMB protocol
  • LeighWardle
    • May 2025
    [Misc] Bizhub 283 - Trouble setting up scanning with SMB protocol
    Hello, I'm new to this forum.
    I have set up a few other brands/models to use SMB - we are running Windows Server 2008 R2.
    Our PageScope web interface is Version 4.1.2.
    I am struggling to find where I enter the SMB details via the web interface.
    I am happy for all the scanned documents to go to a single folder.
    Any suggestions would be most welcome.
    Regards,
    Leigh
  • TheOwl
    • Nov 2008
    • 1732
    Re: Bizhub 283 - Trouble setting up scanning with SMB protocol
    Here goes:
    1. Web Interface
    2. Scan or Store Address or the picture of a letter box
    3. New Registration
    4. SMB
    5. Use Opening Number
    6. Name: Scan to File (or something similar)
    7. Index the address accordingly
    8. Tick the Main box
    9. Destination: IP address of host (or name if the host name tick box is ticked)
    10. File Path: sharename\childname\childname... (if scanning direct to the share, then just the sharename)
    11. OK
      • 22941
      Originally posted by TheOwl
      Here goes:
      1. Web Interface
      3. New Registration
      4. SMB
      11. OK
      Don't forget the share properties of the folder "sharename":
      Under the Share Tab, either select Everyone > Full Control; or create a user for the scanner, i.e. Scan then give Scan > Full Control.
      On WinVista or Win7 PCs there will be a Security Tab, again give Everyone or new user Scan > Full Control.
      • LeighWardle
        Thanks, TheOwl and blackcat4866, for your suggestions.
        My problem right now is that I am remote from the Bizhub and am relying on another guy to operate the Bizhub "hands on".
        He says he cannot find any entries in the Fax/Scan address book.
        But according to the web interface there are 2 entries registered:
        1. Email to someone@somewhere.com (this doesn't have any SMTP settings entered)
        2. Scan to folder (SMB)
        Do the addressbook entries get validated when they are entered? - no error was reported when I completed the Scan to folder (SMB) configuration.
        Do I need to get my man in front of the Bizhub to look harder?
        Regards,
        Leigh
        • TheOwl
          • Nov 2008
          • 1732
          The entries could be indexed under something like ABC, DEF and so on. Get your onsite person to press Fax/Scan and look through the address book indexes that are displayed.
          If a job errors, then the machine will display the error at the time that it occurred. If you want to view past errors (until the machine was last turned off and on again) then use the following:
          1. Job List
          2. Job Details
          3. Send
          4. Job History
          5. Select errored job
          6. Detail
          This will display more information than the standard error which the Konica Minoltas display which basically says that there was an error.
          • LeighWardle
            Hi TheOwl,
            1. Job List
            2. Job Details
            3. Send
            4. Job History
            6. Detail
            Sorry, but I have tried every Icon on the web interface and cannot see anything relating to jobs.
            Regards,
            Leigh
            • TheOwl
              • Nov 2008
              • 1732
              Sorry, I should have mentioned that those steps are from the machines interface and not the web interface.
              From the web interface:
              1. Web Interface (As a public or registered user)
              2. Job or the Green Box
              3. Job History
              4. Change from Print to TX
              5. Go
              You should now see the job history for scanning.
              • LeighWardle
                Thanks, TheOwl, for all your help.
                It's all working now!
                Regards,
                Leigh
                • TheOwl
                  • Nov 2008
                  • 1732
                  Good stuff.
                  What was the issue in the end?
                  • LeighWardle
                    Good stuff.
                    I think my man at the copier end wasn't pressing the right buttons!
                      • 22941
                      Ah! The old user/interface problem. I'm glad you got it figured out. =^..^=
                      • odv
                        i know i'm a little late but our bizhub wont scan to anything. i basically gave up on scanning to email but on the SMB for scan to folder the printer keeps giving me the login error.
                        i know the ip of the server, but apparently im either using a wrong username/password combination, or am setting the file path wrong. my username/password has access to every folder in the sharedrive though.
                        thanks in advance
                        • TheOwl
                          • Nov 2008
                          • 1732
                          thanks in advance
                          If you are getting a login error, that means that the host and file path are correct, you now just need to sort out the user name. The things that I would look at are:
                          1. Is the account locked out due to too many login attempts?
                          2. Is the password definitely correct (reset the password again to make sure)?
                          3. Are the NTFS permissions on the folder set correctly?
                          4. Does the Administrator credentials work?
                          5. Is the machines set to NTLM v1/v2 within the SMB Client Settings?
                          • JR2ALTA
                            • Feb 2010
                            • 2028
                            Could also be a domain issue. enter the domain on the copier, or at least try domain/user name
                            • odv
                              not really sure what you mean by the last one. the printer is already set up on the network and all computers access it. i read something about creating a separate user just for it but we have a pretty tight policy about users so i used my server account.
                              if you could provide an example itd really help. we have a number of files within the server, say server\\v:\ and then a number of files that have restricted access; my account for example, can access all those files, so whats the problem with me using my credentials for the printer? would it trigger if its noticing two devices using the same credentials?
