Need part for a Konica/Minolta DF-611 ADF (on C253 K/M), Any Ideas
  • Doug James
    • Jan 2012
    • 935
    [Misc] Need part for a Konica/Minolta DF-611 ADF (on C253 K/M), Any Ideas
    Part Number 9J07 R707 00, It is the gear assy and motor in the ADF that raises the paper. Need to find supplier for Konica Bizhub C253 parts. Used or new doesn't matter. Thanks so much
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: Need part for a Konica/Minolta DF-611 ADF (on C253 K/M), Any Ideas
    Would You like to explain us what is the matter? Only because KM has posted LOTS OF BULLETTINS (tad) ON THIS (vERY JAMMER ) adf..
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • Doug James
      • Jan 2012
      • 935
      You bet, The shaft attached to the base of the assembly that holds the upper part of a "pivot assembly" to the lwr frame has broken an the motor is also shot. Tried to fix the shaft be re-enforcing it with a screw and building a better base to the shaft only after re-installing found the motor was shot.
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        Ok, so no chances. Try posting this into the Parts Room....maybe there you can have more attenction at your request..
        I do have here an used 611, but is better for you to find a supplier more near than me 1415-a105911.pdf
