Adding print to C252
  • repeatcopiers
    • Sep 2008
    • 591
    I have a c252 w/print and one without. What is involved is swapping the print to the copier w/o.
  • Darren King
    copiertech
    • 652
    Re: Adding print to C252
    C252 came from factory with print onboard. It wasn't an option. It LAN connector is on the right hans side just above the scanner interface cable.
    Hope this helps.
    Darren
    • TheOwl
      • Nov 2008
      • 1733
      Print and Scan from the factory.
      You will just need to setup the device on the network correctly.
      • montana
        • Aug 2008
        • 393
        hi..you need cross cable to connect the machine then you set up as network printer...the printer is standard
        on this model...thanks
        • TheOwl
          • Nov 2008
          • 1733
          You don't need a cross over cable at all, but it will work.
          Computers and Laptops and even switches auto sense on the ports and will automatically cross the TX and RX lines if required.
          • mrwho
            Major Asshole!
            • 4298
            Most of them will, but not all.
            Mascan42
            Ibid
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2141
              are you talking about one of those old school parallel port and usb port option cards ?
              I actually have one of those sitting around collecting dust for some unknown reason.
              But, as everyone else says, you can print via a correctly configured network setup.
