C250 utility butoton not working wont trbl reset
  • kitaarjacquess
    • Jul 2025
    [Dead] C250 utility butoton not working wont trbl reset
    G'day all
    I Got a C250 that wont allow me to press the utility button, hense wont allow me to get to enter the service mode or view meter readings or anything for that matter, however when i try the trbl restet method of switching oon while holding it then the dot appears in the corner as usual but it never goes to the trouble reset tab
    I tried getting around it by unplugging the HDD and Fax board to create codes so that I could maybe try to access the service mode that way
    stil
    no luck
  • mrwho
    Major Asshole!
    • 4299
    Re: C250 utility butoton not working wont trbl reset
    If your Utility button is physically bust, then I see no other way around it than to repair/replace the operation board.
    Mascan42
    Ibid
    • TheOwl
      • Nov 2008
      • 1732
      Does the machine beep when you press the Utility button once the machine has fired up?
      If not, then it sounds like there could be a stuck button on the control panel, or the video interface cable near the LAN port needs to be pulled out and put back in again (with the machine turned off).
      • kitaarjacquess
        It's not a button issue, it does respond.
        It's not a control panel issue, button does respond when trying to trouble reset.
        Then Machine hangs on Konica Minolta logo.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • mo0651
            • 1054
            The touch screen has failed... under accessability key there is a touch screen adjustment, but probably past that already. There is alot of discussion about this and tech bulletins.
            • TheOwl
              • Nov 2008
              • 1732
              If the machine is hanging at the Konica Minolta logo, then you need to update the firmware.
              • JR2ALTA
                • Feb 2010
                • 2033
                Dude, you're a business man, lose the creepy/goofy pic!
