Konica Minolta bizhub PRO 950 with C2811 codes
    • 23006
    The give-away on this one was the times of occurrence: 0650 and 1550 nearly every day within a few minutes. And the error usually occurs when idling.
    Finally set up the PQA. Within the recording window the error occurred at 0624. Have a look at 0624 ...
    Hmmm ... maybe a power issue?
  • mervyn
    • Jul 2011
    • 90
    Re: Konica Minolta bizhub PRO 950 with C2811 codes
    Looks like a power issue , had a similar problem on a C360 , same time in the morning 3 weeks in a row. Turned out the power company were doing work on a transformer at that particular time and causing a voltage fluctuation . Advised customer to get a 20 amp UPS and problem solved . Hope this helps .
      • 23006
      Confirmed. No codes since power was fixed. And just silence from the customer, after "It couldn't possibly be the power ... "
      I wouldn't mind hearing: "Thanks so much for helping us solve our power issues, and not billing us extra for the additional services." Maybe when hell freezes over. =^..^=
