Just wondering if anyone else has a problem with these machines not transporting the waste toner into the box! I have a continuing problem with one machine that seems to clog the exit area of the transport belt cleaning auger. I feel that the auger is not long enough and instead of the waste toner being moved fully to the chute it just pushes it into a mass which then cannot move down into the waste box. I get a call every month for abnormal noise..caused by the auger stalling and the drive gears jumping. Stripping out the cleaning area and a quick vac out does the job..but only until the next time! I have checked the belt systems against another machine and it is the same..the chute is clear and correctly fitted..just doesn`t do the job! Any ideas?
![Confused](https://www.copytechnet.com/core/images/smilies/confused.png)
