Bizhub 353 Tray 1 feed roller replacement
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Just replaced rollers for tray 1, if anyone knows the engineer who designed this, please kick him in the nuts!
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Bizhub 353 Tray 1 feed roller replacement
    Where have you been?
      • 22942
      Yeah, Konica Minolta have to be the most difficult rollers to change in the industry. Canon/HP was the first to use clip on rollers on stub shafts, and most everyone else followed suit most of a decade ago. =^..^=
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        clip on clip off rollers are finally here with the new range of machines.
        (still not as easy as you still have the white plastic clips and the crappy 1 way bearings are still there)
        PS, im changing tray 1 rollers in a c203 on Monday, its a good excuse to plant Ur ass on the ground and chill-ax with a screwdriver removing the bypass tray etc.
        If your not chillaxed, your in the wrong profession
        • minimerlin
          • 851
          You forget that the Minolta Di30 had very easy to change rollers, swing out the left hand side and there they were..slide on/off, even a user could do it! Then it was all down hill ...
          Please do not PM me without asking first.
