bizhub 350 says out of toner when printing
  • DOE
    • Mar 2010
    • 258
    i have a konica 350 that is full of toner and copies fine but when they go to print it says its out of toner,. this happened after a big storm. dont nknow much about the print option. do i need a new print unit? thanks for any advice
  • KM7155
    • Aug 2008
    • 145
    Re: bizhub 350 says out of toner when printing
    u mean "full of toner" is ur toner bottle full of toner or the toner hopper full of toner?
    if ur toner bottle full of toner, ur toner bottle probably did not turn.
    have to make sure the toner hopper is working, normally the toner sensor is in the hopper
    unit.
    • Hansoon
      • Sep 2007
      • 3252
      @ KM7155: Perhaps when you shorten toner to ton, hopper to hop, bottle to bot and probably to prob it would be easier to understand your writing.
      Good grieve.......
      Hans
      " Sent from my Intel 80286 using MS-DOS 2.0 "
      • KM7155
        • Aug 2008
        • 145
        Good grieve.......
        Hans
        @Hans, are u facing difficulty to understand my writing?
        • Hansoon
          • Sep 2007
          • 3252
          Yes.
          Hans
          • KM7155
            • Aug 2008
            • 145
            Yes.
            Hans
            Haha, too bad.
            • pepper38_cnd
              Field Service Manager
              • Aug 2005
              • 1076
              In the print driver Port setting uncheck the SNMP box, you should not see any messages from the printer with this unchecked. Also make sure in the configure tab, under aquire settings the Auto box is unchecked.
              Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
              Now into Ip TV KODI Boxes
              • JustManuals
                • Jan 2006
                • 9931
                Paul@justmanuals.com
