POOR KEYBOARD RESPONSE
  • CPF
    • Jul 2025
    [Misc] POOR KEYBOARD RESPONSE
    hi everyone, customer complaining about poor keyboard / ops panel response. km2560.
    will try a factory reset see if that helps, any of you guys come across this problem and fixed.
    any advice appreciated.
    best mab
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: POOR KEYBOARD RESPONSE
    Clean around the edges of the touch panel up under the cover...dirt and grime can get up in there...then initialize the op panel with U201 then do a U906....that will fix the problem a majority of the time.....
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • b3p0
      • Feb 2012
      • 60
      Kidaver is right, try that first. it's only worked for me 50% of the time.
      I replace the panel if that doesn't fix it. Its a resistive touch panel that sits on top of the LCD as a separate assembly.
      Here is the part number:
      302H094270 PARTS,TABLET OPERATION,SP
      If you do replace the touch panel, make sure to re-flash the firmware on the machine just to be safe(there's a TB about that), then re-calibrate ( u201).
      Good luck
