Biz Hub C352
  • Zookeyman
    • Feb 2012
    • 26
    [Misc] Biz Hub C352
    Working with C352. Paper size auto select works THROUGH the ADF and print services, for ALL sizes of paper. Put the paper on the glass and it ALWAYS calls for 11X17 paper, regardless of actuall size. Where is the setting to change this to Auto select? Looked through the users and service manual, I looked in User and Admin settings.
    I can"t do a Factory Default reset as the end user has ALOT of special settings for his Mac computor and company functions.
    help?
  • Darren King
    copiertech
    • 652
    Re: Biz Hub C352
    This may help.
    10.4.4 Org. Size Detecting Sensor Adj.
    1.
    2.
    Call the Service Mode to the screen.
    3.
    Touch these keys in this order: [Machine] [Org. Size Detecting Sensor Adj.].
    4. Press the Start key.
    Darren
    • copytechman
      • Nov 2008
      • 926
      Re: Biz Hub C352
      Yep try that, seen the c250 series pull that stunt on occasion... (same sensor arrangement under the glass)...
      It's that or a failed original sensor or even a stuck reset arm on the back of scanner assy (the finger that sticks up or down depending on the model to tell the machine you've "reset" whats on the glass.
      Regards!
      A.
      • Zookeyman
        • Feb 2012
        • 26
        Re: Biz Hub C352
        Thanks for the replys.... I'll give it a try...
        Thanks again, I'll post our results.....
