c6500 not fusing toner at all
  • jzheld
    • Sep 2010
    • 162
    Have and issue c6500 will not fuse toner at all. I tried to increase temperature, changed all one way gears, changed limiter, so it's ether just hang with "warming up" message or print but not fusing at all, any kind of paper. Need help please, anything you can think of.
    Thank you.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: c6500 not fusing toner at all
    Thank you.
    I'm very surprised that no error codes come up. As you know Any C-37xx code indicates a problem with the fuser roller temperature. In the complete absence of those codes or any other error code for that matter..... I would suspect you have no or little pressure between the fuser belt and the lower roller. Pressure is not being applied evenly to the fusing rollers causing the temperature sensor to read the incorrect temperature
    Did anybody just service or replace parts in the fuser unit? That's my best stab in the dark. Hope that helps.....Good luck and let us know what fixes it.
    • inutelkamo
      • Jul 2011
      • 143
      hey there..
      please kindly check the pressure off the fixing belt and that lower roller.. it might dont have pressure to press down toner. and check the life to fixing belt and roller, it might need to be change..
      • mariappanpm
        • May 2012
        • 14
        Check Release Actuator position in Fuser unit .
        Remove the actuator and rotate 180 degree and fix it.
        (there are two positions to fix the actuator. It may be fixed in wrong position)
        That may be a problem.
        • jzheld
          • Sep 2010
          • 162
          Thank you, just fixed it last night, it appears that there was no pressure at all when it grabbed the paper and than the pressure has been applied, so it was working kind of in reverse. So i just repositioned the pressure roller. Fuser was serviced, just before that, one of the one way gear wasn't working.
          Thank you for your help.
          • jzheld
            • Sep 2010
            • 162
            Thank you, that fixed the problem.
