Magicolor 2590MF
  • linuxxpwin
    • May 2008
    • 205
    Magicolor 2590MF
    Good day all, I have here a Konica Minolta Magicolor 2590MF, where the image transferred to the paper begins at least 3 inches down and while exiting fixing assembly creates a paper jam.
    I have checked all Sensors all is good, I check rotary position also is doing fine. the scanner is working fine, machine appears to be ok.
    Machines only have 110 copies in total, but have been down for a while as the owner could not locate a technician who can look at it, until now.
    I have the service manual and parts manual, but unable to find anything that could be causing my issue.
    Paper tray sensor - ok
    registration sensor - ok
    exit sensor -ok
    clutches - ok
    solenoids - ok
    Any suggestions I would be grateful.
    Linuxxpwin
  • Hansoon
    • Sep 2007
    • 3355
    Re: Magicolor 2590MF
    Sticky solenoid and or clutch goo-yed up.
    Replace the black patch where the solenoid anchor sticks to.
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
      • 22954
      Nice photos Hans. Apparently you've seen this one before. =^..^=
      • Hansoon
        • Sep 2007
        • 3355
        Thanks Cat. Yes, I have several of these in the field. I always make pictures when in the workshop doing weird things which are often hard to explain verbally. It is intended for my colleagues but also for myself cause I tend to suffer from CRS.......
        Hans
        • linuxxpwin
          • May 2008
          • 205
          Thanks guys, I did clean the solenoid of the rubber stuff and replace it, but I found that the solenoid is not firing, will try another later tonight, however I may need to modify as I do not have those here in stock.
          Will report later on updates.
          linuxxpwin
          • linuxxpwin
            • May 2008
            • 205
            Ok, Thanks to all the help, I was able to resolve issue had a bad solenoid, modified it with a Canon as parts are not available here, and got everything working, will be placing order for correct part, as this is only a temp measure to keep customer going.
            Thanks again all.
            linuxxpwin
            • Hansoon
              • Sep 2007
              • 3355
              Weird, I never had a whole solenoid not working. Did you replace the black patch with something the same thickness? If its too thin than the anchor itself will stick to the frame by magnetic force.
              Hans
              • linuxxpwin
                • May 2008
                • 205
                yes i did, I even tested outside of machine it just does not get energize, after modifying with a Canon replacement, it worked then.
                I am indeed grateful for all the information given.
                linuxxpwin
