Bizhub 282 Fax
  • bashboosh
    • Dec 2011
    • 24
    Bizhub 282 Fax
    Hi,
    I have a Bizhub 282 with 2 fax lines. One is used for national fax and the other for international. I have installed the Network fax software in a PC hoping to send fax from system. My concern is, how can I choose the line while sending fax from PC if i want to sending an international fax or national line fax?
    Secondly, Is there a setting to send the status report to admin's email after sending/failing on transmission?
    Thanks for your support.
  • bashboosh
    • Dec 2011
    • 24
    Re: Bizhub 282 Fax
    Wish to get a response..
      • 22939
      Re: Bizhub 282 Fax
      As with all dual line faxes you can only transmit from one of the lines, defaulted in the service mode to option1. You can receive on both lines, but can only send on one.
      This is a common misunderstanding. =^..^=
      • bashboosh
        • Dec 2011
        • 24
        Re: Bizhub 282 Fax
        Hi,
        Thanks for the reply. I understand that fact.
        regards to my second question, is there a way to get the status report of the sent fax by mail? ( i already have the LDAP, SMTP settings working in MFP)
        Thanks again
