My machine will not accept a print over the network.
I have installed, and re-installed the drivers to no avail.
I can ping it fine.
I can access it on the web server just fine.
It is in perfect working order.
I have had it set for both a fixed IP and DHCP with no difference either way.
When I send a print, it acts as though everything is perfectly fine.
The PC sends it and it leaves the que on the PC (Windows 7 Ultimate) just fine.
It indicates no error in the printing or sending of the que.
But when I look on the copier it does not show up in the job que.
It is as if it recieves the information and does nothing with it.
The data light blinks green on and off.
I have it set up for TCP raw, directly to the IP and port 9100.
I have even tried setting the network settings to default and starting from scratch with no joy.
I have complete administrative control over the whole system. I can log in and out and change anything I need to.
Where are the print jobs going?
I have also been unable to get it to send a scan out as an email. It has always done this fine in the past.
It had always printed over the network fine in the past as well, up until about a year ago.
I can ping it fine.
