Edit serial number bizhuh C35
  • sangcom
    • Jun 2009
    • 45
    Hi All.
    I am Tenichial sopport , I Renew control board and IC Chip on control board for Bizhub C35 ,but serial number remodel , how to edit serial number
    "I DO"
    1.AUTPRN.DEF
    2.DateTime.reb
    3.DateTime.pjl
    Copy file 1-3 to flash drive
    and edit file "DateTime.pjl"
    code
    %-12345X@PJL
    @PJL SET SERIALNO = "xxxxxxxxxxxxx"
    %-12345X
    but not work
    ''How to edit...Thank you"
  • Unlimitedcreationslimo
    • Feb 2020
    • 6
    • femaster
      • May 2011
      • 1466
      Re: Edit serial number bizhuh C35
      Did you follow the procedure in the service manual for the board replacement?
      First, which board did you replace, PRCB, or MFPB? If it's the PRCB, then yes, you must swap the EEPROM chip from the old to new board. And make sure the notch on the chip lines up with the notch on the socket. Pull STRAIGHT up, VERY gently but firmly, do not bend the pins or crack the chip with a screwdriver. Also a good idea to make sure you have discharged any static electricity before you play around with it.
      Contents
      Trouble code
      Trouble type
      Relevant electrical parts
      13DD
      Backup data error - The engine counter data and the controller counter data are inconsistent.
      • [*=left]Print control board (PRCB)
        [*=left]MFP board (MFPB)
      (2)Procedure
      Step
      Action
      Control signal
      Location (electrical component)
      1
      Select [Service Mode] / [BK Clear], and execute the BK Clear function.
      2
      Check the connector between MFPB CN16-PRCB PJ21 for proper connection and correct as necessary.
      3
      Change PRCB.
      4
      Change MFPB.
      • allan
        RTFM!!
        • 5459
        Google "8-pin DIP IC" and look at the image. Does the original board have one of those on there?
        Whatever
          • Feb 2020
          • 6
          Can u see photo
            • Feb 2020
            • 6
            [ATTACH=CONFIG]44944[/ATTACH] [ATTACH=CONFIG]44945[/ATTACH]
            Contents
            Trouble code
            Trouble type
            13DD
            (2)Procedure
            Step
            Action
            Control signal
            1
            2
            3
            Change PRCB.
            4
            Change MFPB.
            Mine is different it has a aluminum housing in the middle
              • Feb 2020
              • 6
              Here is a photo
                Originally posted by Unlimitedcreationslimo
                Here is a photo
                where?
                • femaster
                  • May 2011
                  • 1466
                  Here is a photo
                  There has been no photos in any of your posts. If by "aluminum housing" you mean a heatsink, then it is the MFPB. Does it look like this?
                  If so, that is a whole different ball game. Multiple steps including changing bit switch settings, swapping things back and forth, booting and rebooting...
