Ikon Powerpro controller and bizhub Pro C500
  • rindraintsoa
    • Sep 2010
    • 55
    Hi all,
    I have a "communication" problem between a Ikon Powerpro RIP(IC301) and a Bizhub Pro C500, before the cummunicate correctly but since I have got a black dev problem, they can't communicate anymore. The black dev pb is solved now. But when I start up the controller, the RIP says "establishing connections" whenever the copyer is in ready state. I would like to mention that when I am in 25 mode the rip says machine is in sleep mode, when I switch off the copier it is identified via the controller that the copyer is swityched off (check alimentation cable message). I have tried to swap the data cable with a working one but still having the same problem. I guess it is a configuration to made it working but don't know where. Doesn't seen any configuration in 25 mode neither in 36 mode. Would you please help me.
    Thanks in advance
  • rindraintsoa
    • Sep 2010
    • 55
    Re: Ikon Powerpro controller and bizhub Pro C500
    Hi all,
    Does anyone found similar case to mine? did anyone find any solution I am desperately looking for a solution please. I was wondering if there was any configuration to tell to the C500 that a creo controller is connected to it (like on the office solution C550/450 and others where in service mode you can tell the machine which controller is connected to it).
    Thanks in advance for your suggestion
    • RRodgers
      • Jun 2009
      • 1947
      What are the chances the connection cable became disconnected while the power was on?
      • rindraintsoa
        • Sep 2010
        • 55
        I think there is a chance that the cable was disconnected while the controller and the copyer was ON. Do you think that there is a possibility to recover this issue?
        Thank you in advance.
        • RRodgers
          • Jun 2009
          • 1947
          Last time we had that happen to us we had to spend thousands of dollars on image processing boatd
          • rindraintsoa
            • Sep 2010
            • 55
            So definitely there is no chance to solve this kind of problem without changing the board? isn't there any dipswitch or something similar to do a hard reset of the board?
            • rindraintsoa
              • Sep 2010
              • 55
              Just a stupid question did you try to rewrite or update the firmware on the engine ?
              • RRodgers
                • Jun 2009
                • 1947
                I don't think so, as I'm sure it was killed electrically.
