BIzhub B363 Scan to Email as TEXT not HTML
  • flysa1
    • May 2025
    [Misc] BIzhub B363 Scan to Email as TEXT not HTML
    Hi evryone,
    I have three B363 models at a client. 2 of the machines, when using scan to email, and opening the email in Outlook will open as an HTML format message. The other machine's email will open as TEXT format message. This happens on the same computer as well as other computers. The emails come through correctly with the PDF attached file, but the message itself shows in Text format instaed of HTML format from this specific machine.
    Any help will be much appreciated.
    • 22942
    Re: BIzhub B363 Scan to Email as TEXT not HTML
    This has got to be an email client setting or browser setting. Nothing to do with your scanner or the network it's on.
    Unless you're supporting the endusers software applications, this is not your problem. =^..^=
    • B0265
      • Jan 2007
      • 718
      Does any of the machines have some body text in the e-mail message?
      • flysa1
        Yes it does have text, then I removed that under admin mode, but still sends it as text format and not html.
