Hi guyz my Bizhub c451 has following problems
* It ask's to me change the Transfer belt (how can i fix it by just replacing the fuse & if i don't at a point will it stop printing?)
* All 3 color IMU have reached end of life and machine is asking to replace them (how can i reset the counter and will the machine stop working if i don't change them?)
* I changed the Black toner but the indicator showed 3/4 full, so i removed the toner shaked, placed back in then it showed 2/4 filled and after a day use it now shows 1/4th fill, although its working fine since 3 months now even at that 1/4th fill level is it eating toner? or just a glitch?
* most importantly since 1 month i see these small lines small black lines which appear only on the 1st black printed/copied pages, color comes out fine, pic is attached below
as usual your kind efforts/responses would be very much appreciated
