I am working on a Konica/Monolta bizhb 600 and it is jamming (code C1702) and the paper ends up past the invertion upsidedown under the duplexer. The copy went past the fuser and it kept going. Here comes the twist, because it only does it from tray 1. I have replaced paper feed unit, horizontal coveyance, bypass and fuser unit. besides replacing the copier what else can I do? Thanks.
Paper ends up upsidedown under duplxer.
Re: Paper ends up upsidedown under duplxer.
ignore the paper under the duplex, this is coincidental. I had this once, you'll find it's either the one way gear cluster at the rear right corner of the machine, accessible by removing the bypass assembly, you'll see a cluster of 3 or 4 white gears with a belt drive, dissemble this and clean the clutches and shafts, takes about 15 mins, or more likely one of the clutches in the vertical feed assembly is slipping. remove all of the covers on the right hand side of the machine and remove the vertical feed assembly (with lower right hand door) about 12 screws, once out, clean the rollers and clean/replace/swap the uppermost clutch. that sorted it on my one, but the paper under the duplex kept me going around in circles for hours! -
ignore the paper under the duplex, this is coincidental. I had this once, you'll find it's either the one way gear cluster at the rear right corner of the machine, accessible by removing the bypass assembly, you'll see a cluster of 3 or 4 white gears with a belt drive, dissemble this and clean the clutches and shafts, takes about 15 mins, or more likely one of the clutches in the vertical feed assembly is slipping. remove all of the covers on the right hand side of the machine and remove the vertical feed assembly (with lower right hand door) about 12 screws, once out, clean the rollers and clean/replace/swap the uppermost clutch. that sorted it on my one, but the paper under the duplex kept me going around in circles for hours!Comment
I am working on a Konica/Monolta bizhb 600 and it is jamming (code C1702) and the paper ends up past the invertion upsidedown under the duplexer. The copy went past the fuser and it kept going. Here comes the twist, because it only does it from tray 1. I have replaced paper feed unit, horizontal coveyance, bypass and fuser unit. besides replacing the copier what else can I do? Thanks.Please do not PM me without asking first.Comment
I checked the mylar in the invertion unit, it was OK. I had the problem with the mylar a couple of times but when the mylar is ripped it would jam rigth there, at the mylar. This thing moves the paper past the guide and lands underneath the duplex. Thanks for your input.Comment
Just had this on a 7165, turned out to be the ADU board.Color is not 4 times harder... it's 65,000 times harder. They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.Comment
It is either one of the sensors above the transport section above the 2nd tray, or it is one of the clutches that drives the rollers in that transport section.
Hope this helpsComment
