View Full Version : Miscellaneous Bizhub 654 - Unicode
fancheta
11-18-2013, 04:44 PM
I had to reformat an HDD in a bizhub654 and now on the control panel, it is stating to install unicode fonts. I have the unicode fonts on a USB drive but no idea how to install them. I tried reflashing the fw as well but still prompts that message.
Already looked thru service mode 2 > install data.
This machine has licenses for unicode fonts and pdf/a fonts (already installed).
JustManuals
11-18-2013, 07:47 PM
http://www.justmanuals.com
paul@justmanuals.com
dallas
11-18-2013, 10:00 PM
This is easy to handle.
- Extract the OCR_Font_Data_USB.exe
- Copy the 4 PDF-Files to the root directory of the USB-Stick
- Connect the USB Memory on the right side of the control panel
- Select the Button "Print a Document from external Memory"
- The font Data in the USB Memory will be displayed, select these Files to print out
- A error message will be displayed (Printing failed), but that's normal. Touck OK
Print out a PCL Font List and confirm that the Font data (Anadale Mono WTJ, Andale Mono WTK, Andale Mono WTS, Andale Mono WTT) are registered.
fancheta
11-19-2013, 07:51 AM
thanks
