Prints are fine. Only happens in copy and scan modes. Mono, color, single color. Lines are very thin and are approx 1mm apart.
Bizhub C652 horizontal lines
Re: Bizhub C652 horizontal lines
Paul@justmanuals.com
Simply too many variables--need more.
Scan it in 600x600dpi and jpg compress it, we should be able to see it fine
([non]color=no toner)Comment
My guess is the scanner process board, or the ribbon cable that connects it to the Sys board. Since prints are fine you can rule out all of the image formation items, sounds like the image is being garbled during the scan process. If the lines are about 1/2 inch apart and uniform vertical/horizontal, then I would recommend performing the initial setup steps. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.Comment
Me? I'd start at the CCD and start re-seating connectors. Be especially careful with the ribbon cables. I've seen techs create far more interesting problems by mishandling the ribbon cables. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
The lines-of-shame occur at 12mm, so at 1mm I'd think it was something else.
Me? I'd start at the CCD and start re-seating connectors. Be especially careful with the ribbon cables. I've seen techs create far more interesting problems by mishandling the ribbon cables. =^..^=Comment
Okeer
I had the same trouble with a C452 and it was a memory error on the MFP board. After replacing the MFP board, everything was fineComment
i think swap CCD because this lines is from bad image creation from scanner ccd not a physical problems in scanner like scan motor mirrors and other scan parts.Comment
if it prints ok, its a memory issue - usually fail memory stick has gone bad.. replace, then if still there go to the mpf board...
but check all connectors first, and does the same lines happen when scanning?Comment
tnrtt has a lot of things to check, but probably the quickest and easiest thing to do is a memory check in Service Mode.
If NG try memory modules.
Then unfortunately the replacement of the MFP board.
However, do not depend on those memory checks as being unequivocal I have had memory checks pass even with a bad DIMM.Comment
Thanks a lot, Okeer. Replacing the memory did the trick. This forum is great. No matter how weird the problem, somebody here has encountered it.Comment
