Does any one know what this could be? I perform trouble reset but it keeps coming back. Had to replace the MFP board but would like to repair it if possible.
Konica Minolta C-203 service code BOO3
Tags: None
Re: Konica Minolta C-203 service code BOO3
If you disable the fax option with in service mode this should hopefully get rid of the code. if it has a fax unit fitted re-seat the option board and make sure the FK-502 is connected fully.
i hope this helps -
Sounds like someone removed the fax board and didn't turn it off in service mode. System 2- option board status.Comment
http://www.justmanuals.com
Paul@justmanuals.comComment
