konica 350 alignment problem
  • DOE
    • Mar 2010
    • 258
    i have a konica 350 that makes a copy that is straight on the lead and trail side but crooked on the top and bottom. as you look at the copy the sentences run down hill but the sides of copy are straight. if i draw a square on paper and make a copy the lead and trail sides are straight but top and bottom are crooked. any ideas thanks
  • minimerlin
    • 851
    Re: konica 350 alignment problem
    twisted scanner?
    Please do not PM me without asking first.
    • Hansoon
      • Sep 2007
      • 3350
      twisted scanner?
      Ditto.
      Look at the front of the machine and likely you will notice that the scanner unit droops down at the left side. Just yank it upwards and tell your customer not to lean on it again.
      Hans
      “ Sent from my Intel 80286 using MS-DOS 2.0
      https://www.copytechnet.com/images/smilies/biggrin.png
